How can I customize my Dashboard in Suunto app?
In Suunto app, you can customize the widget in the home page dashboard, allowing you to see the information you care more about at a glance.
To do so, tap and hold on the dashboard; the customization display will appear. Remove unwanted dashboard widgets by tapping the minus (-) sign; Add widgets by pressing the plus (+) sign: you can select them from the list that appears (widgets that are already in use are not in the list). Tap on done once you are done with the customization.
NOTE: the dashboard customization is stored locally, and not in your account. This means that:
  • You can have different dashboards on different devices (for instance, your phone and a tablet); and in turn you need to customize each device individually.
  • On the other hand, if you uninstall Suunto app or log out, the dashboard will revert to default and you’ll need to customize it again.
READ MORE:
