Software updates – Suunto 9 Peak Pro
Enjoy the convenience of over the air software updates via Suunto app so that your Suunto 9 Peak Pro always has the latest and greatest software.
Over the air software update
When an update is available and your watch is connected with Suunto app, the software update will be downloaded to the watch automatically.
Once the software is downloaded to your watch, the watch will update itself during the night as long as the battery level is at least 50%.
If you want to install the update manually before it happens automatically during the night, navigate to Settings > General and select Software update.
Release notes
2.40.38
Staged update starting on March 25th 2025.
This update brings improvements and bug fixes.
Improvements and bug fixes:
  • Treadmill calibration is not anymore affected by outdoor runs
  • Pool swim distance accuracy improved further
  • Daily HR and sleep tracking problems solved
  • WiFi connection stability improved
  • Support for new watch face types
  • Map download speed improved
  • Improved turn-by-turn notification logic
  • Map screen visible during pause
  • 22 New sports introduced. Now more than 100 sports to track with the watch:
    Backcountry skiing, Biathlon, Calisthenics, Chores, Classic skiing, Cyclocross, E-Biking, E-MTB, Field hockey, Futsal, Hand cycling, Meditation, Parkour, Pilates, Skate skiing, Skateboarding, Ski mountaineering, Split boarding, Track running, Vertical Running, Wheelchair sport, Yoga
2.39.34
Aggiornamento in più fasi a partire dal 6 Gennaio 2025.
Downgrade temporaneo dal software precedente al fine di risolvere un problema critico causato dall’aggiornamento più recente. Il software è identico alla versione 2.37.48.
2.39.20
Aggiornamento in più fasi a partire dal 16 dicembre 2024
Questo aggiornamento apporta nuove funzionalità, miglioramenti e correzione di errori.
Nuove funzionalità:
  • Supporto per i nuovi quadranti natalizi nel SuuntoPlus Store
  • Aggiunto supporto per la calibrazione automatica della bussola
  • Aggiunta un’opzione di blocco pulsanti nel pannello di controllo
  • Migliorato l’aspetto visivo dei menu dell’orologio
Miglioramenti e correzione di errori:
  • Migliorata la precisione della distanza outdoor con il nuovo firmware GNSS
  • Risolti i problemi relativi alla FC giornaliera e al monitoraggio del sonno
  • Le app per lo sport SuuntoPlus mostrano lo stato di connessione del dispositivo
  • Diverse correzioni dei bug e miglioramenti della stabilità
2.37.48
Aggiornamento graduale a partire dal 2 ottobre 2024
Questo aggiornamento porta le seguenti correzioni di bug:
  • Risolti i casi in cui il monitoraggio del sonno e l'OHR smettevano di funzionare
  • Risolto un caso in cui la distanza di nuoto in piscina era errata nel registro
  • Risolto un caso in cui il consumo di energia rimaneva elevato dopo la navigazione
2.37.34
Aggiornamento in più fasi a partire dal 4 settembre 2024
Questo aggiornamento apporta nuove funzionalità e correzione di errori.
Nuove funzionalità:
  • I quadranti dell’orologio sono stati spostati nel SuuntoPlus Store
  • Dopo l’aggiornamento, l’orologio ha un solo quadrante e i nuovi quadranti possono essere aggiunti all’orologio dal SuuntoPlus Store nell’app Suunto.
  • Pannello di avvio dell’esercizio semplificato e più veloce
  • Miglioramento della capacità di determinare il valore di VO2max
  • Miglioramenti alla funzionalità di Istruzioni climb
  • Diversi miglioramenti estetici ai menu e ai quadranti dell’orologio
  • Alcune correzioni linguistiche alle versioni tradotte
2.35.34
Aggiornamento in più fasi a partire dal 3 luglio 2024
Nuove funzionalità:
  • Funzionalità “Istruzioni climb” durante la navigazione per gli itinerari inclusi i dati di altitudine
  • Possibilità di selezionare le complicazioni dei quadranti dell’orologio
  • Tre nuovi quadranti dell’orologio
  • Campi per i dati cumulativi come complicazioni dei quadranti dell’orologio
  • Secondo accesso rapido configurabile
  • Blocco schermo in modalità orologio
  • Campo dati sullo schermo di navigazione
  • Impostazioni specifiche del display per la modalità sport
  • Ritorno alla schermata precedente mediante la pressione prolungata del pulsante centrale nella modalità sport
  • Nuova interfaccia utente per pausa ed esercizio con possibilità di navigazione tra le varie schermate
  • Supporto lingua vietnamita
  • Supporto emoji migliorato con più caratteri
  • Contapassi migliorato per evitare il rilevamento errato dei movimenti generici della mano
  • Navigazione UI più rapida
  • Nuovo software GNSS e OHR
2.33.16
Aggiornamento in più fasi a partire dal 21 maggio 2024.
  • Corretto il bug che causava la mancata sincronizzazione col dispositivo mobile
  • Risolto un problema con le guide dell’allenamento strutturato SuuntoPlus
2.33.14
Aggiornamento in più fasi a partire dal 23 aprile 2024
  • correzione dell’errore che causava lo spegnimento del dispositivo nel caricabatterie
  • Risolto un problema con la comunicazione del dispositivo SuuntoPlus
2.33.12
Aggiornamento pianificato a partire dal 25 marzo 2024.
Questo aggiornamento porta nuove funzionalità, miglioramenti e correzioni di bug.
Nuove funzionalità:
  • Tre nuovi quadranti dell'orologio
  • Promemoria di pausa e ripresa del registro all'inizio del movimento
  • Prima versione del supporto agli emoji nelle notifiche mobili
Miglioramenti e correzioni di bug:
  • Miglioramento delle prestazioni di sincronizzazione dei dati delle zone di allenamento
  • Velocità di sincronizzazione dell'app Suunto migliorata
  • Risoluzione dei problemi di stima della gara di corsa
2.30.38
Aggiornamento pianificato a partire dal 18 dicembre 2023.
Questo aggiornamento apporta miglioramenti e correzioni di bug.
Miglioramenti e bug corretti:
  • Diversi miglioramenti alla stabilità generale
  • Icona del meteo mancante nel widget risolta
  • Funzionalità del pulsante di giro risolta nelle guide SuuntoPlus
  • Problemi di rendering del riepilogo del registro in alcuni casi risolti
  • Risolti alcuni problemi di tracciamento del sonno e del contatore dei passi
2.30.32
Aggiornamento in più fasi a partire dal 30 novembre 2023.
Nuove funzionalità:
  • Nuova struttura intuitiva dell'interfaccia utente con mini widget e una personalizzazione più varia
  • Nuovi widget della Training Zone per il Punteggio dello stress da allenamento (TSS), i progressi (CTL) e il recupero (HRV e TSB).
  • Misurazione del recupero HRV durante il sonno
  • Più sveglie invece di una sola
  • Funzione “Trova il mio telefono”
  • Promemoria per alzarti
  • Nuove app sport SuuntoPlus in alcune modalità sport predefinite
  • Stime delle gare di corsa per 5 km, 10 km, mezza maratona e maratona
Miglioramenti:
  • Stabilità migliorata
  • Nuovo layout della schermata di riepilogo del registro
  • Qualità delle icone delle notifiche migliorata
  • Qualità dei comandi multimediali migliorata
  • Miglioramento dell’accuratezza GNSS con l’aggiornamento del firmware GNSS
2.27.8
Versione pubblicata in più fasi a partire dal 28 giugno 2023
Nuove funzionalità:
  • Segmenti live di Strava sull'orologio
  • Assistenza per due app sport SuuntoPlus durante la sessione
  • Le app sport SuuntoPlus vengono ricordate nel corso delle sessioni
  • Assistenza per le impostazioni delle app sport SuuntoPlus
  • Nuovo widget Condizioni meteo per le previsioni del giorno
  • Funzione torcia nel menu
  • Comandi vocali attraverso l’app Suunto
  • Nell’edizione globale sono attivate le lingue tailandese e cinese tradizionale.
Miglioramenti:
  • Miglioramenti alle impostazioni della retroilluminazione
2.22.60
Versione pubblicata gradualmente a partire dal 29 novembre 2022
Questo aggiornamento apporta miglioramenti alle prestazioni del GPS in un orologio.
Miglioramenti:
  • Tempi più brevi per trovare il segnale GPS
  • Precisione del posizionamento migliorata
  • Riacquisizione più rapida del GPS dopo una perdita di segnale
2.22.58
Pubblicazione dal 25 ottobre 2022
Questo aggiornamento apporta alcune nuove funzionalità e correzioni di alcuni bug.
Nuove funzionalità:
  • Assistenza per le connessioni dei dispositivi SuuntoPlusTM
  • Potenza della corsa misurata al polso
  • Modalità sport Snorkeling e Mermaiding
