Suunto Ocean User Guide
Navigation
You can use your watch to navigate in various ways. You can, for example, use it to orient yourself in relation to magnetic north, navigate a route or to a point of interest (POI).
To use the navigation feature:
  1. Swipe up from watch face or press the lower button.
  2. Scroll down to Map and select it.
    Map Menu Phoenix
  3. The map display shows your current location and the surroundings.
    Map View
If the compass is not calibrated, you are prompted to calibrate the compass when you enter the map.
  1. Press the lower button to open a list of shortcuts. The shortcuts give you quick access to navigation actions such as checking the coordinates of your current location or selecting a route to navigate.
    nav options Phoenix
