Sign up for the newsletter and get 10% off | Easy returns
Compare the different Suunto D-Series dive computers and choose the right one for your needs.
The Suunto DM5 allows you to download your dive logs for advanced analysis and create dive plans. Transfer dive logs from your compatible Suunto dive computer, upload dive plans, and customize your dive computer.
Find your nearest official Suunto dive product retailer from the dealer locator.
Measurements | 45,6 x 48,5 x 15,9 mm / 1,8 x 1,91 x 0,63 " |
Weight | 137 g / 4,83 oz |
Bezel material: | Stainless steel |
Glass material: | Sapphire crystal |
Case material: | Steel |
Strap material: | Textile |
What's in the box? | Suunto D6i Novo Stealth Zulu with stealth Zulu strap, D-series USB cable, safety leaflet, quick guide, dive legal leaflet with warranty information and Suunto logo sticker |
Country of manufacture | FI |
Water resistance | 150 m (ISO 6425, EN 13319) |
Battery life 100 dives/year | 1.5 years |
Battery type | CR 2450 |
Time, date | |
Alarm clock | 1 daily alarm |
Dual time | |
Stopwatch timer | |
Languages | EN |
Backlight | electro-luminescent |
Configurable backlight | duration: off, 5, 10, 20, 30, 60 s |
Display type | matrix |
Display resolution | 49 x 22 |
Battery indicator | low battery indicator |
Metric and imperial units |
In time mode | 2 years |
Data transfer | USB cable |
Connectivity (between devices) | inductive |
Compatible with DM5 |
Digital compass | |
Tilt compensation | up to 45° |
Declination correction | |
Direction scale | degrees |
Needle | compass rose |
Globally balanced | |
Bearing lock with direction indicator | |
Compass accuracy | 5° |
Compass resolution | 1° |
Operating temperature | 0° C to +40° C / +32° F to +104° F |
Storage temperature | -20 ° C to +50 ° C / -4° F to +122° F |
Maximum operating depth (EN 13319) | 150 m |
Nitrox (and air) | |
Freedive | |
Gauge | |
Dive time | 0 to 999 min |
Surface time | 0 to 99 h 59 min |
No fly time | |
Safety Stop | |
Deep Stop | |
Ascent time display | 0 - 199 min (- - after 199) |
CNS/OTU (OLF) calculation | |
Wireless air integration | optional |
Gas time | |
Decompression model | Suunto RGBM |
Personal adjustment | 0 - 2 |
Altitude adjustment | 0 - 300 m / 300 -1500 m / 1500 - 3000 m |
Gases | up to 3 gases (Oxygen 21 - 99%) |
Gas max pO2 | 1.2 - 1.6 |
Gas switching | |
Timer | |
No-decompression planner | |
Logbook memory | ~140 h (20 s sampling rate) |
Logbook bookmarks | |
Logbook sampling rates | 10, 20, 30, 60 s (1, 2, 5 s freediving) |
Dive history | lifetime |
Dive time | |
Maximum depth | |
Tank pressure | |
Gas time | |
High pO2 (hyperoxic) | |
Too fast ascent | |
Decompression ceiling violation | |
Deepstop violation | |
CNS/OTU (OLF) 80% / 100% | |
Switch gas (better gas is available) |
Apnea timer (O2/CO2 tables) | |
Freedive number | |
Freedive day history | |
Freedive total history | lifetime |
Depth notify | yes (5) |
Surface time notify |
Temperature | |
Temperature display range | -20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F) |
Temperature resolution | 1° C / 1.5° F |
Chrono |
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto dive computer.
