Profitez de la commodité des mises à jour logicielles à distance via l’application Suunto afin que votre montre Suunto Ocean dispose toujours du logiciel le plus récent et le plus performant.
Notes de version
2.36.18
Staged update starting on September 5th 2024.
This update brings new features, improvements and bug fixes.
New features:
  • Provide the compass heading while scuba diving
  • New view for freedive mode to list all dives, depth, dive time and surface times
  • The automatic start for scuba dive will always start with the latest scuba dive mode
  • New options to adjust the safety stop and how TTS is calculated during decompression dives
  • Average gas consumption value in dive summary to be calculated from real-time values during diving
Improvements and bug fixes:
  • Fixed bug for adjusting brightness during freedive
  • UI improvement to the Gas list
  • Fixed bug that caused an empty dive list in the exercise summary in Snorkeling mode after firmware update
  • Improved calculations for pool, open water and snorkelling distances
  • Fixed issue for showing wrong surface time in scuba history widget
  • Fixed issue for not showing HR belt icon if OHR is disabled in dive pre-dive screen
  • Fixed bug related to showing the gas switch recommendation while descending
  • Updated the surface pressure also when not in water sports to prevent dive modes to start automatically if surface pressure drops
  • Fixed bugs related to not being able to confirm alarms while freediving
  • Added low battery alarm for freedive, mermaiding and snorkeling
  • Changed the arch behaviour for decompression and safety stops
  • Increased the range for surface time duration to show days
  • Improved the dive alarm behaviour to better tackle situations with multiple simultaneous dive alarms
  • Removed additional time added to safety stop if fast ascent happened during diving
