Merci de m'alerter lorsque ce produit sera à nouveau en stock
Cette adresse e-mail n'est pas valide
Votre pays ou région :
{{ slotScope.modalForm.formError }}
{{ slotScope.modalForm.success }}
New features for Suunto 7
Save emissions with your muscles
Track your human-powered commutes with Suunto app. You can now tag your rides, runs, walks and other activities as "commutes" and learn how much CO2e emissions you have saved compared to driving that same distance.
Select the right trail for you
Whether you are a gravel, MTB or road cyclist, the new road surface information in Suunto app, allows you to plan your route exactly where it fits your bike and mood.
Just enable one road surface at a time or all options together to see paved, unpaved and rough paths.
See your routes in 3D
Planning routes with Suunto app in 3D helps you get a comprehensive understanding of what lays ahead – and reviewing your adventures in 3D can bring back great memories!
Offline music
Download music to your Suunto 7, connect your headset to the watch and listen without a connection or data charges.
Sleep tracking
Wearing Suunto 7 at night with sleep tracking enabled shows you how long you sleep and how restorative your sleep is, helping you to maintain a healthy sleep schedule. Setting a sleep goal and a bedtime reminder will help you to develop better sleep habits. Over time, you’ll learn how your sleep patterns affect your body, and what the best recipe for your rest and recovery is.
Body resources
Suunto 7 measures your activity, stress, and recovery throughout the day, showing how sleep and exercise affect your body and helping you to maintain a healthy balance. Good sleep is an essential part of ensuring your body has the resources it needs, so each morning your Suunto 7 will show the resources you have gained during the night and what your total body resources are when you wake up.
Fréquence cardiaque journalière
La fonction de fréquence cardiaque journalière vous permet de mesurer rapidement votre fréquence cardiaque actuelle. Un graphique journalier montre comment votre fréquence cardiaque fluctue lors de vos phases d'activité et de repos.
Navigation étape par étape
Ne vous égarez plus grâce aux alertes de navigation étape par étape Planifiez votre itinéraire sur l'appli PC ou mobile de komoot et synchronisez-le avec votre Suunto 7 avant de partir. À l'approche d'un virage, vous recevrez une alerte pour pouvoir profiter du paysage au lieu d'avoir les yeux rivés sur votre montre. En savoir plus sur komoot.
Battery-saving GPS mode
Selecting 'Good' location accuracy makes the battery last longer during your outdoor workouts. Prepare for longer sessions or use it when you are already low on battery and want to keep going. When running or cycling, FusedTrack™ is used to improve tracking quality. Learn more about FusedTrack™
Your display stays awake all the time while you exercise, using only a minimum amount of battery. This enables you to constantly see all your training data without having to raise your wrist to activate the display.
Route navigation
Create your own route, use tracks from other services or select a popular trail in the Suunto app. Sync the route to your watch and off you go! With route navigation on your watch you'll always find your way.
Popular routes
Getting bored of running the same trails but not sure where to go? We made finding new routes easy for you by adding popular routes to the Suunto app. These routes are generated from the exercises of the Suunto community.
Popular starting points
When heading to a new place or route, it’s often hard to figure out where to start. Check out popular starting points in the Suunto app to easily know where to start your adventure from. The popular starting points are also visible with heatmaps on Suunto 7.
My tracks
See your own personal heatmap with a daily, monthly, and current year view. You can also compare your tracks with the most popular routes for your sport.
MyRadar
Quickly see what weather is coming your way with MyRadar. This app gives you real-time weather with local animated weather maps so you can plan your outdoor adventures. Read more about MyRadar.
These new features and functionalities are available through the latest system update.
Google, Android, Google Play, Wear OS by Google, Google Pay and Google Fit are trademarks of Google LLC. Wear OS by Google works with phones running Android 6.0+ (excluding Go edition) or iOS 12.0+. Supported features may vary between countries and platforms.
The Empire State Building image® is a registered trademark of ESRT Empire State Building, L.L.C. and is used with permission.
Assistance Suunto 7
Trouvez le guide d'utilisation complet, des vidéos explicatives et des informations d'assistance détaillées pour votre montre Suunto.
