We love the sounds of nature when out adventuring – but sometimes life is just better with music.
With LED lights, a battery life of up to 10 hours and an additional 20 hours from the external powerbank, the Suunto Wing bone conduction sports headphones are the perfect way to combine both.
Open-ear technology allows you to listen to music and at the same time still hear your surroundings. Instead of traditional in-ear headphones, Suunto Wing sits on your jawbone leaving your ear canal open to stay aware of the nature or traffic around you.
Suunto Wing features red LED lights on both sides of the head, so that in dim conditions whether on the trails or on the roads you are more visible. You can choose between different light modes or turn them on/off with your Suunto app.
For the adventures that keep your hands busy, Suunto Wing comes with Head Movement Control. This feature allows you to skip to the next song or answer a phone call simply by shaking or nodding your head instead of pushing a button.
From blazing hot to freezing cold, from getting covered in dust & sweat to showering it all off at home – Suunto Wing is made so you can enjoy your adventures in all types of conditions and still listen to your favourite songs.
Up to 10 hours of battery life with one charge. For those longer adventures, Suunto Wing comes with portable a powerbank that adds another 20 hours of music playtime. And if you do run out of power, a quick 10-minute recharge gives you 3 hours of audio for your training.
Connect Suunto Wing to Suunto app on your phone to get the most out of your headphones. Change your preferred sound mode or switch the LED lights from constantly on to a blinking mode. With Suunto app changing settings is just a tap on the screen away.
Measurements | 102.5 x 126.5 x 46.5 mm / 4.04 x 4.98 x 1.83 " |
Weight | 33 g / 1.16 oz |
Case material: | Silicone + Titanium Alloy |
What's in the box? | Suunto Wing headphones, Headphone charging cable, Powerbank, Suunto storage bag, Earplugs, Printed user quick guide, International warranty leaflet, Safety leaflet |
Country of manufacture | CN |
Firmware upgradable | |
Water resistance | IP67 |
Battery type | rechargeable lithium-ion |
Battery Charge Time | Headphones:≤1h |
Music only play time | ≧10H, Used with powerbank: ≧30H (60% volume, using SBC format to play 'Hotel California') |
Music play time after opening head movement control | ≧8H |
Music play time after the LED lights in the constant light | ≧4H |
Size | 93.5mm*48mm*25mm |
Case material | Plastic |
Weight | 40g |
Water resistance | IP55 |
Operating temperature | -20° C to +60° C / -5° F to +140° F |
Storage temperature | -20° C to +60° C / -5° F to +140° F |
Recommended charging temperature | 0° C to +45° C / +32° F to +113° F |
Smartphone compatibility | Most common models supported |
Compatible with Suunto app | |
Software updates from cloud | |
Bluetooth | |
Bluetooth Range | > 10m |
Supported Audio Formats | A2DP, AVRCP, HFP, HSP |
Dual device connection |
Size | L22.1mm*W13.15mm*H6.5mm |
Impedance | 6Ω±15% |
Frequencyrange | 20Hz~20kHz |
Sensitivity | 117dB@1kHz -10dBFS |
T.H.D | <5% 300HZ-4kHz |
S/N Ratio | 62.5dB |
Sensitivity | -38dB(1kHz) |
Frequencyrange | 100Hz~10KHz |
Find the full user guide and other detailed support information for your Suunto headphones.
Your country or region:
United States
