Suunto Wing User Guide
Dual device connection
You can connect your Suunto Wing to two Bluetooth devices at the same time. With the help of the dual device connection function, you can easily switch to your phone and answer a call while listening to music from your computer.
Follow these steps to pair your headphones with two devices:
When the headphones are switched off:
  1. Keep the + button pressed for 5 seconds to switch the headphones on and enter pairing mode.
  2. While the red LED lights are blinking, keep the multifunction button and the + button pressed simultaneously for 3 seconds to enable dual device connection. The headphones will play a sound when the function is enabled.
  3. Under the Bluetooth settings of the first compatible device, open the list of nearby devices.
  4. Find Suunto Wing in the list and pair the headphones with the first device.
  5. Keep the + and – buttons pressed simultaneously for 3 seconds to enter pairing mode again.
  6. Under the Bluetooth settings of the second compatible device, open the list of nearby devices.
  7. Find Suunto Wing on the list and pair the headphones with the second device.
  8. When you connect the second device, the first device temporarily disconnects from the headphones. To reconnect the first device, go to the Bluetooth settings of the device or simply restart the headphones.
When the headphones are already switched on and paired with a device:
  1. Keep the + and – buttons pressed simultaneously for 3 seconds to enter pairing mode.
  3. Under the Bluetooth settings of the second compatible device, open the list of nearby devices.
  4. Find Suunto Wing on the list and pair the headphones with the second device.
  5. When you connect the second device, the first device temporarily disconnects from the headphones. To reconnect the first device, go to the Bluetooth settings of the device or simply restart the headphones.
When the headphones are already switched on and paired with a device with Suunto app:
  1. Enable dual device connection in Suunto app.
  2. Keep the + and – buttons pressed simultaneously for 3 seconds to enter pairing mode.
You can check the list of the connected devices in Suunto app.
When you use Suunto Wing with two paired devices at the same time, the headphones determine their own priority based on the order of the played content and the tasks. Normally, the first played audio takes precedence over the second, and phone calls take precedence over audio playback. However, the actual operation of different brands and models of the compatible devices may vary.
