Adjusting settings
To access and adjust the settings:
- Keep Next pressed to enter the options menu.
- Scroll the menu with Start Stop and Light Lock.
- Press Next to enter a setting.
- Press Start Stop and Light Lock to adjust the setting values.
- Press Back Lap to return to the previous view in the settings, or keep Next pressed to exit the options menu.
You can access the following options:
Personal
- Birth year
- Weight
- Max HR
- Gender
GeneralFormats
- Language
- Unit system
- Metric
- Imperial
- Advanced: Allows you to customize a mix of imperial and metric settings according to your own liking in Movescount.
- Position format:
- WGS84 Hd.d°
- WGS84 Hd°m.m'
- WGS84 Hd°m's.s
- UTM
- MGRS
- British (BNG)
- Finnish (ETRS-TM35FIN)
- Finnish (KKJ)
- Irish (IG)
- Swedish (RT90)
- Swiss (CH1903)
- UTM NAD27 Alaska
- UTM NAD27 Conus
- UTM NAD83
- NZTM2000
- Time format: 12 h or 24 h
- Date format: dd.mm.yy, mm/dd/yy
Time/date
- GPS timekeeping: on or off
- Dual time: hours and minutes
- Alarm: on/off, hours and minutes
- Time: hours and minutes
- Date: year, month, day
Tones/display
Compass
- Calibration: Start compass calibration.
- Declination: Set the compass declination value.
Map
- Orientation
- Heading up: Displays the zoomed-in map with the heading pointing up.
- North up: Displays the zoomed-in map with the north pointing up.
The alarm will sound even when all tones are off.
Pair
- Bike PODs: Pair a bike POD.
- Power POD: Pair a power POD.
- HR belt: Pair a HR belt.
- Foot POD: Pair a foot POD.
- Cadence POD: Pair a cadence POD.
