In case you want to delete all your settings from Suunto Wing, you can reset the product. While Suunto Wing is charging, keep the multifunction button pressed for 5 seconds. When the red LED lights blink twice and the headphones play a sound, the reset is successful.
After the reset, the Bluetooth pairing records are deleted from the headphones. When you want to use the headphones again, you have to start the pairing process from the beginning. See Pairing.
