您可在 Movescount 中建立路線,或匯入其他服務建立的路線。
若要新增路線時:
也可透過 Movescount 刪除路線。
You can navigate a route you have transferred to your Suunto Traverse from Movescount (see 3.20 Routes) or from a log in your logbook with GPS data. You get a preview of the route based on the route list or logbook selection.
If you are using the compass for the first time, you need to calibrate it (see Calibrating compass). After activating the compass, the watch will begin searching for a GPS signal. After the watch acquires a GPS signal, you can begin to navigate a route.
To navigate a route:
You can also start navigating while recording an activity (see Recording activities).
導航時,按下
,即可轉至下列視圖:完整軌跡視圖會向您顯示以下資訊:
在完整軌跡視圖中,正北方向始終朝上。
您可以利用選項功能表的 NAVIGATIONNAVIGATION(導航)» SettingsSettings(設定) » MapMap(地圖)» OrientationOrientation(方位),以調整地圖的方位。
在爬升過程檢視內容中,會顯示以下的資訊:
如果您大幅偏離路徑軌道,即無法更新路徑圖。相反地,會在圖的下方顯示文字 Off routeOff route(偏離路徑)。您需要回到軌道上才能準確地加總計算。
