Buy Suunto Ocean or EON Core - Save 50% on Tank Pod. Shop now!
With the integrated navigation, Suunto Traverse is your ideal companion on treks and hikes in the wild. Check out the full collection and stories behind this product.
Find your nearest official Suunto sports watch retailer from the dealer locator.
Every new Suunto product goes through rigorous testing during development both in the laboratory and out in the field. In addition to our internal testing, we let independent test laboratories put our products to the limit. See how Suunto Traverse was tested according the military standards (MIL-STD-810G). Watch the video now.
Measurements | 50 x 50 x 16.5 mm / 1.97 x 1.97 x 0.65 " |
Weight | 80 g / 2.82 oz |
Bezel material: | Stainless steel |
Glass material: | Mineral crystal |
Case material: | Composite |
Strap material: | Silicone |
What's in the box? | Suunto Traverse White, USB cable, quick guide, warranty leaflet |
Country of manufacture | FI |
Water resistance | 100 m |
Battery type | rechargeable lithium-ion |
Firmware upgradable | |
Time, date | |
Alarm clock | 1 daily alarm |
Dual time | |
Automatic timekeeping | |
Countdown timer | |
Stopwatch timer | |
Languages | EN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH |
Backlight | LED |
Configurable backlight | brightness / mode |
Button lock | customizable |
Invert display | |
Display type | matrix |
Display resolution | 128 x 128 |
Battery indicator | percentage / icon |
Metric and imperial units | |
Memory left indicator | |
Flashlight backlight option | |
Vibration alert | |
Automatic daylight saving time |
In time mode | 14 days |
Training mode with GPS | 10, 15, 100 h |
Smartphone compatibility | Most common models supported |
Data transfer | Wireless / USB cable |
Watch customization | USB cable |
Connectivity (between devices) | Bluetooth Smart |
Phone notifications on the watch | with Suunto App |
Compatible with online sports communities | Strava, TrainingPeaks, MapMyFitness and others (available in Suunto app) |
Compatible with Suunto Apps | |
Max. nr. of apps per sport mode | 4 |
Logging of app specific metrics | |
Most recommended apps by activity | |
Chrono, GPS, HR, weather and altitude data | |
Rich math functions, if/then-logic, sound, backlight, etc. | |
Create own metrics with advanced formulas |
Digital compass | |
Tilt compensation | full |
Declination correction | |
Direction scale | degrees / mils |
Needle | north indicator |
Bearing lock with direction indicator | |
Compass accuracy | 5° |
Compass resolution | 1° |
Operating temperature | -20° C to +60° C / -5° F to +140° F |
Storage temperature | -30° C to +60° C / -22° F to +140° F |
Recommended charging temperature | 0° C to +35° C / +32° F to +95° F |
Satellite systems | GPS, GLONASS |
GPS recording rate | Best, Good, OK |
Coordinate systems | WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000) |
Waypoint and visual route navigation | |
Max. nr. of Points of Interest (POIs) | 250 |
Find back | |
Route planning | in Suunto Movescount.com |
Track logging, viewing and sharing | in Suunto App |
Route points per route / POIs in watch | 1000 / 250 |
GPS track analysis | in Suunto App |
Breadcrumb trail in real time | |
Route planning with altitude profile | in Suunto Movescount.com |
Route altitude profile navigation in real-time | |
Track back | yes, incorporated with breadcrumb trail |
Barometric altitude | |
GPS altitude | |
Combined GPS and barometric altitude (FusedAlti™) | |
Altitude graph | |
Total ascent/descent | air pressure based |
Vertical speed | air pressure based |
Automatic alti/baro profile | |
Altitude difference | in log summary, and real time as an App |
Log recording rate | 1, 10 s |
Resolution | 1 m |
Range | -500 - 9999 m |
Sea level pressure | |
Sea level pressure graph | |
Weather trend indicator | |
Temperature | |
Temperature display range | |
Sunrise/sunset times | |
Storm alarm | |
Tide information | yes** |
Temperature resolution | 1° |
Pressure resolution | 1 hPa / 0.03 inHg |
Max weather recording length | past 26 hours |
GPS speed and distance | Integrated |
Distance based autolaps | |
Chrono | |
Laps | > 1000 |
Autopause |
Heart rate in beats per minute | |
Heart rate in % of max hr | |
Records heart rate in swimming | yes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor |
Calories | |
Log summary on the watch with lap details | |
Training analysis | in Suunto App |
Training logbook with story and image support | in Suunto App |
Customizable sport modes and displays | 5 modes / 4 displays per mode |
Running pace | |
Average pace in real time | |
Lap comparisons by kilometer/mile | |
Suunto FusedSpeed™ |
Cycling speed | based on GPS |
Average speed in real time | based on GPS |
Step counter |
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
Your country or region:
United States
