Suunto Ambit2 R has a 3D compass that allows you to orient yourself in relation to magnetic north. The tilt-compensated compass gives you accurate readings even if the compass is not horizontally level.
The compass is a temporary display that needs to be activated.
To activate the compass:
compass mode includes the following information:
The compass will switch itself to power saving mode after one minute. Reactivate it with
.For information on using compass during exercise, see Using compass during exercise.
