Buy Suunto Ocean or EON Core - Save 50% on Tank Pod.
Flash Sale: Up to 50% off on selected products! Discover
Suunto Core User Guide
Using weather trend indicator
The weather trend indicator is located on the upper side of the display. It is displayed in the time and alti & baro modes, providing you with quick reference to check upcoming weather conditions. The weather trend indicator is comprised of two lines forming an arrow. Each line represents a 3-hour period. The right line represents the last 3 hours. The left line represents the 3 hours prior to the last 3 hours. So the line can indicate 9 different patterns in the barometric trend.
Using trend indicator big1
Situation 3-6 hours agoSituation last 3 hours
Using trend indicator 7Dropped heavy (>2 hPa/3hours)Dropping heavily (>2 hPa/3hours)
Using trend indicator 2Remained stableRising heavily (>2 hPa/3hours)
Using trend indicator 9Rose heavy (>2 hPa/3hours)Dropping heavily (>2 hPa/3hours)
If the weather trend indicator shows that the air pressure is constantly rising, there is a higher possibility of sunny weather upcoming. Again, if the air pressure is constantly dropping, there is a higher possibility of rainy weather.
