Sign up for the newsletter and get 10% off | Easy returns
Measurements | 50 x 50 x 15٫5 mm / 1٫97 x 1٫97 x 0٫61 " |
Weight | 70 g / 2٫47 oz |
Bezel material: | Plastic |
Glass material: | Mineral crystal |
Case material: | Polyamide |
Strap material: | Silicone |
What's in the box? | Suunto Ambit2 R White HR, Suunto ANT Heart Rate Belt, Ambit power cable, and Quick guide |
Country of manufacture | FI |
KEY TRAINING FUNCTIONS
This product is ANT+™ certified.
Visitwww.thisisant.com/directory for a list of compatible products.
KEY OUTDOOR FUNCTIONS
Declination correction | adjustable |
Water resistance | 50 m |
Battery type | rechargeable lithium-ion |
Firmware upgradable | |
Time, date | |
Alarm clock | 1 daily alarm |
Dual time | |
Automatic timekeeping | |
Countdown timer | |
Stopwatch timer | |
Languages | EN, DE, ES, FI, FR, IT, NL, PT, SV |
Backlight | LED |
Configurable backlight | brightness / mode |
Button lock | customizable |
Invert display | |
Display type | matrix |
Display resolution | 128 x 128 |
Battery indicator | percentage / icon |
Metric and imperial units | |
Autoscrolling of exercise displays | |
Memory left indicator |
In time mode | 14 days |
Training mode with GPS | 8, 12, 25 h |
Data transfer | USB cable |
Connectivity (between devices) | Suunto ANT, ANT+ |
Compatible with Suunto Apps | |
Max. nr. of apps per sport mode | 5 |
Logging of app specific metrics | |
Most recommended apps by activity | |
Create own metrics with advanced formulas | |
Chrono, GPS, HR, weather and altitude data | yes, excluding weather |
Running, cycling, swimming data | yes, excluding cycling power/swimming |
Rich math functions, if/then-logic, sound, backlight, etc. |
Digital compass | |
Tilt compensation | full |
Direction scale | degrees / mils |
Needle | north indicator |
Bearing lock with orienting indicator | |
Compass accuracy | 5° |
Compass resolution | 1° |
Operating temperature | -20° C to +60° C / -5° F to +140° F |
Storage temperature | -30° C to +60° C / -22° F to +140° F |
Recommended charging temperature | 0° C to +35° C / +32° F to +95° F |
Satellite systems | GPS |
GPS recording rate | 1, 5, 60 s |
Coordinate systems | WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000) |
Waypoint and visual route navigation | |
Max. nr. of Points of Interest (POIs) | 100 |
Find back | |
Track logging, viewing and sharing | |
Route planning | |
Route points per route / POIs in watch | 1000 / 100 |
GPS track analysis |
GPS altitude | |
Altitude graph | |
Total ascent/descent | GPS based |
Vertical speed | GPS based |
Altitude difference | yes** |
Log recording rate | 1, 10 s |
Resolution | 1 m |
Range | -500 - 9000 m |
Distance based autolaps | |
Chrono | |
Laps | > 1000 |
Autopause | |
GPS speed and distance | Integrated |
Foot POD support | Suunto Foot POD / ANT+ |
RR interval | |
Heart rate in beats per minute | |
Heart rate in % of max hr | |
Real-time average and max heart rate | |
Heart rate limits | |
EPOC & V02 max values | |
Heart rate graph in real time | |
Calories | |
Peak Training Effect | |
Recovery time | |
Real time EPOC | yes** |
Speed and heart rate-based guidance during exercise |
Log summary on the watch with lap details | |
Training analysis | |
Training logbook with story and image support |
Customizable sport modes and displays | 10 modes / 8 displays per mode |
Running pace | |
Suunto FusedSpeed™ | |
Average pace in real time | |
Running cadence | watch or Foot POD |
Foot POD calibration | manual or GPS |
Average stride length | yes** |
Marathon End-time Estimator | yes** |
Lap comparisons by kilometer/mile |
Cycling speed | based on GPS |
Average speed in real time | based on GPS |
Hill incline in real time | yes, available as Suunto Apps |
Openwater swim pace and distance |
Your country or region:
United States
