Soldes de printemps : jusqu'à 20% de remise sur une sélection de produits ! Découvrir
The power of long, steady training sessions
SuuntoRun — 21 جانفي 2025
Long, steady training sessions might not be flashy, but they're vital for building both endurance and resilience.
When it comes to endurance sports, success isn’t just about speed or intensity. It’s about the ability to sustain effort over time, to push through challenges and maintain performance when it counts most. But what is the secret to building this kind of resilience? The answer lies in long, steady training sessions – a cornerstone of any effective endurance training program.
The importance of long, steady sessions
Long, steady training sessions are the foundation upon which endurance capacity is built. These sessions – often performed at a consistent, moderate intensity – are designed to improve your body’s ability to sustain prolonged efforts. They lay the groundwork for more advanced training phases, such as speed work and high-intensity intervals, by establishing a robust aerobic base. Without this base, efforts to improve speed or power are often short-lived, as the underlying endurance isn’t there to support them.
By consistently incorporating these sessions into your routine, you build the stamina required to tackle longer distances and improve your overall efficiency as an endurance athlete. They’re not just about going the distance; they’re about preparing your body to perform at its best over time.
Physiological benefits
One of the primary benefits of long, steady training sessions is improved aerobic efficiency. When you train at a moderate intensity, your body adapts by increasing mitochondrial density in your muscles. Mitochondria are the energy powerhouses of cells, and more mitochondria mean your muscles can produce energy more efficiently. This adaptation allows you to rely more on fat as a fuel source, sparing glycogen stores for when you need them most, such as during a race’s final push.
Another significant adaptation is the growth of capillaries – the small blood vessels that deliver oxygen and nutrients to your muscles. Long, steady sessions stimulate the development of these vessels, enhancing oxygen delivery and waste removal. Over time, this leads to greater endurance and the ability to sustain higher workloads with less fatigue.
How to execute long, steady sessions
Executing these sessions correctly is key to reaping their benefits. Here are some guidelines to help you get it right:
Define "long and steady"
A long, steady session should be performed in your aerobic zone. For most athletes, this corresponds to Zone 2 heart rate or a level of effort where you can comfortably maintain a conversation. It’s not about pushing hard; it’s about staying consistent and controlled.
The length of your session will depend on your fitness level and goals. Beginners might start with 60 minutes, while more experienced athletes can aim for 90 to 120 minutes or more. For ultra-endurance athletes, these sessions may extend even further.
Pacing tips
Suunto watches offer multiple ways to guide your training intensity. Suunto ZoneSense is a new, revolutionary method of tracking your exercise intensity. It measures heart stress through heart rate variability (HRV), offering real-time insight into training intensity. ZoneSense is driven by the advanced DDFA index, which tracks changes in metabolic state. What this means in practice, is that Suunto ZoneSense provides accurate feedback on whether your intensity is aerobic, anaerobic, or reaching VO2 max levels. This helps you to stay in the optimal training zone for your long sessions.
You can also set up your heart rate, power and pace zones on your Suunto based on your anaerobic threshold values.
One of the simplest ways to gauge your pacing on those long runs is the talk test: if you’re breathing too hard to speak in full sentences, you’re likely going too fast. Keep the effort sustainable and avoid the temptation to speed up.
Common pitfalls to avoid
Even with the best intentions, it’s easy to make mistakes that undermine the effectiveness of your long, steady training sessions. Here are two common pitfalls to watch out for: going too fast and neglecting recovery.
One of the most frequent errors is creeping into the “gray zone,” a moderate-to-high intensity that’s too hard to be truly aerobic but not hard enough to build anaerobic capacity. Training in this zone too often can lead to fatigue without significant gains.
Long sessions place significant stress on your body, and recovery is essential to adapt and improve. Ensure you’re getting enough rest, sleep, and nutrition to support your training load. Also, remember the importance of fueling already during your long sessions.
Conclusion
Long, steady training sessions are more than just a box to check on your training plan—they’re a fundamental component of endurance success. By building your aerobic base, enhancing physiological efficiency, and fostering mental resilience, these sessions prepare you to perform at your best when it matters most. Consistency and patience are key, so trust the process and watch your endurance performance soar.
Read more
Why training intensity matters in endurance training
Suunto ZoneSense revolutionizes intensity insights with heart stress measurement
