Sign up for the newsletter and get 10% off | Easy returns
Measurements | 49.1 x 49.1 x 14.5 mm / 1.93 x 1.93 x 0.57 " |
Weight | 83 g / 2.93 oz |
Bezel material: | Steel |
Glass material: | Mineral crystal |
Case material: | Composite |
Strap material: | Silicone |
What's in the box? | Suunto Core Gray Crush and Quick Guide |
Country of manufacture | CN |
Water resistance | 30 m |
Battery type | CR2032 |
User replaceable battery | |
Time, date | |
Alarm clock | 1 daily alarm |
Dual time | |
Countdown timer | |
Stopwatch timer | |
Languages | EN, DE, ES, FR |
Backlight | electro-luminescent |
Configurable backlight | activation: 1 button, all buttons |
Button lock | |
Display type | matrix |
Battery indicator | low battery indicator |
Metric and imperial units |
In time mode | 12 months |
Digital compass | |
Direction scale | degrees |
Needle | north indicator |
Bearing lock with orienting indicator | |
Compass accuracy | 5° |
Compass resolution | 1° |
Operating temperature | -20° C to +60° C / -5° F to +140° F |
Storage temperature | -30° C to +60° C / -22° F to +140° F |
Depth meter for snorkeling | 10 m |
Barometric altitude | |
Altitude graph | |
Total ascent/descent | air pressure based |
Automatic alti/baro profile | |
Altitude difference | |
Log recording rate | 1, 5, 10, 30, 60 s |
Resolution | 1 m |
Range | -500 - 9000 m |
Sea level pressure | |
Sea level pressure graph | |
Weather trend indicator | |
Temperature | |
Temperature display range | |
Sunrise/sunset times | |
Storm alarm | |
Pressure resolution | 1 hPa / 0.03 inHg |
Temperature resolution | 1° |
Max weather recording length | 7 days |
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
